Inleiding
If the microwave does not power on correctly, the capacitor may be at fault. Always use caution when working with electrical devices.
Wat je nodig hebt
The capacitor stores a small amount of electrical energy. Discharge capacitor by placing a screw driver across the terminals. Use a screwdriver with a non-metallic handle and a shaft that is longer than 4” (10.75mm) Touch the metal shaft of the screwdriver simultaneously to both metal terminals of the capacitor. There should be a spark.
If the capacitor sparks, you can stop reading here. The spark indicates that the capacitor is working properly. If the capacitor does not spark, read on to Step 6.
Één andere persoon heeft deze handleiding voltooid.
