Ga door naar hoofdinhoud
Pyle Astro PTBL7C LCD Replacement
Wat je nodig hebt
  1. Pyle Astro PTBL7C LCD Replacement, LCD: stap 1, afbeelding 1 van 2 Pyle Astro PTBL7C LCD Replacement, LCD: stap 1, afbeelding 2 van 2
    • Using the plastic opening tool, work your way along the edge of the tablet.
    • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
    • Place the front display assembly facing front side down to expose the inside.
  2. Pyle Astro PTBL7C LCD Replacement: stap 2, afbeelding 1 van 2 Pyle Astro PTBL7C LCD Replacement: stap 2, afbeelding 2 van 2
    • Remove the three 4 mm JIS #0 screws to release the PCB board.
  3. Pyle Astro PTBL7C LCD Replacement: stap 3, afbeelding 1 van 1
    • The display is held in place by plastic tabs which slide over the outer edges of the backside of the display.
    • Gently work your way around the display while pulling the plastic tabs back to release the LCD display from the front panel.
  4. Pyle Astro PTBL7C LCD Replacement: stap 4, afbeelding 1 van 1
    • Once all clips are released gently open and separate the front plastic display from the LCD and place the LCD face down.
    • The front plastic display contains the external touch panel, and the capacitive touch screen overlay.
  5. Pyle Astro PTBL7C LCD Replacement: stap 5, afbeelding 1 van 1
    • Using both hands, gently release the ribbon cable to the capacitive touch screen overlay from the PCB board by pushing both gray tabs outwards.
  6. Pyle Astro PTBL7C LCD Replacement: stap 6, afbeelding 1 van 1
  7. Pyle Astro PTBL7C LCD Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
    • Exercise extreme caution and be sure to not rupture the battery casing.
  8. Pyle Astro PTBL7C LCD Replacement: stap 8, afbeelding 1 van 1
Conclusie
Andrew Redifer
265 Reputatie
2 handleidingen geschreven
IUPUI, Team S3-G6, Harley Spring 2018 Lid van IUPUI, Team S3-G6, Harley Spring 2018
IUPUI-HARLEY-S18S3G6
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 286
