Ga door naar hoofdinhoud
Protocol Videodrone AP Propeller Motors Replacement
Wat je nodig hebt
  1. Protocol Videodrone AP Propeller Motors Replacement, Propeller Motors: stap 1, afbeelding 1 van 1
    • Power off the drone before proceeding with the rest of the guide.
  2. Protocol Videodrone AP Propeller Motors Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove four propeller screws.
    • If you don't own the screwdriver included with the drone kit, use a Phillips #0 screwdriver.
  3. Protocol Videodrone AP Propeller Motors Replacement: stap 3, afbeelding 1 van 2 Protocol Videodrone AP Propeller Motors Replacement: stap 3, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove eight propeller guard screws.
  4. Protocol Videodrone AP Propeller Motors Replacement: stap 4, afbeelding 1 van 2 Protocol Videodrone AP Propeller Motors Replacement: stap 4, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove eight housing screws from the bottom of the drone.
  5. Protocol Videodrone AP Propeller Motors Replacement: stap 5, afbeelding 1 van 1
    • Open up housing to reveal main circuit board.
  6. Protocol Videodrone AP Propeller Motors Replacement: stap 6, afbeelding 1 van 2 Protocol Videodrone AP Propeller Motors Replacement: stap 6, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove three motor housing screws. There are three screws per motor.
    • The plastic housing is glued directly to motor.
  7. Protocol Videodrone AP Propeller Motors Replacement: stap 7, afbeelding 1 van 3 Protocol Videodrone AP Propeller Motors Replacement: stap 7, afbeelding 2 van 3 Protocol Videodrone AP Propeller Motors Replacement: stap 7, afbeelding 3 van 3
    • Desolder the wires connecting the propeller motor to the motherboard (2 per motor) and remove the motor from the device.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
Conclusie
Karan Paranganat
352 Reputatie
2 handleidingen geschreven
IUPUI, Team S2-G2, Harley Fall 2019 Lid van IUPUI, Team S2-G2, Harley Fall 2019
IUPUI-HARLEY-F19S2G2
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 370
