Ga door naar hoofdinhoud
Protocol Videodrone AP Battery Wiring Replacement
Wat je nodig hebt
    1. Protocol Videodrone AP Battery Wiring  Replacement, Battery Wiring: stap 1, afbeelding 1 van 1
      • Make sure the drone is turned off
      Vraag FixBot
      Voeg opmerking toe
    2. Protocol Videodrone AP Battery Wiring  Replacement: stap 2, afbeelding 1 van 1
      • Open the hatch and carefully pull out the battery to expose the cable connection
      Vraag FixBot
      Voeg opmerking toe
    3. Protocol Videodrone AP Battery Wiring  Replacement: stap 3, afbeelding 1 van 2 Protocol Videodrone AP Battery Wiring  Replacement: stap 3, afbeelding 2 van 2
      • Carefully pull apart the cable connection
      Vraag FixBot
      Voeg opmerking toe
    4. Protocol Videodrone AP Battery Wiring  Replacement: stap 4, afbeelding 1 van 2 Protocol Videodrone AP Battery Wiring  Replacement: stap 4, afbeelding 2 van 2
      • Unscrew the 4 screws from the bottom of the drone.
      • Unscrew the 8 screws connecting the propeller guards to the drone
      • Unscrew the four propeller screws.
      • One screw is hidden behind the screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Protocol Videodrone AP Battery Wiring  Replacement: stap 5, afbeelding 1 van 1
      • Carefully remove faulty battery wiring from the drone
      Vraag FixBot
      Voeg opmerking toe
    6. Protocol Videodrone AP Battery Wiring  Replacement: stap 6, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Feed through opening using tweezers to grasp the wire and carefully pull through.
      Vraag FixBot
      Voeg opmerking toe
    7. Protocol Videodrone AP Battery Wiring  Replacement: stap 7, afbeelding 1 van 1
      • Use the soldering iron to solder new wires to mother board. CAUTION: Soldering iron may get hot and cause minor burns if handled improperly.
      • Use this guide for how to solder: https://www.youtube.com/watch?v=QKbJxytE...
      Vraag FixBot
      Voeg opmerking toe
    8. Protocol Videodrone AP Battery Wiring  Replacement: stap 8, afbeelding 1 van 1
      • Reattach the battery and test for power by turning on the drone and look for the 4 LEDs turn on.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
All Done!
Één andere persoon heeft deze handleiding voltooid.
Serge
340 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G1, Passmore Fall 2017 Lid van USF Tampa, Team S2-G1, Passmore Fall 2017
USFT-PASSMORE-F17S2G1
4 Leden
3Gids Commentaar
Great explanation. Just wondering where to get the replacement piece. My drone has the black wire hanging by a single strand just outside the white connector. The red wire is in tact but I would need the whole part that attaches to the board and extends outside the drone to connect the battery to. Thanks
yasureok - Antwoord Deel
Was wondering i think its charging the blue light flashes when plugged in but wont turn on. Wires look brand new
Michael Landry - Antwoord Deel
I’m wondering the same thing, mine lights up blue when charging, wires look good but still no action.
Ryann Hunter - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 2,192
