Ga door naar hoofdinhoud
Protocol TerraCopter EVO Drone Motor Replacement
Wat je nodig hebt
  1. Protocol TerraCopter EVO Drone Motor Replacement, Drone Motor: stap 1, afbeelding 1 van 1
    • Orientate the drone to where the black side of the drone face upwards.
    • On the bottom side of the drone, remove the twenty-two 5mm Phillips #1 screws holding the black frame to the body.
    • There is one screw under the rear light. Pry the opaque cover to access the last screw.
  2. Protocol TerraCopter EVO Drone Motor Replacement: stap 2, afbeelding 1 van 1
    • The plastic frames are subject to cracking.
    • Wires run through both frames.
    • Pry the white body away from the black frame.
  3. Protocol TerraCopter EVO Drone Motor Replacement: stap 3, afbeelding 1 van 1
    • Gently pry the motor from it's socket.
  4. Protocol TerraCopter EVO Drone Motor Replacement: stap 4, afbeelding 1 van 2 Protocol TerraCopter EVO Drone Motor Replacement: stap 4, afbeelding 2 van 2
    • Locate these solder points of the leads on the motherboard.
    • From the front of the drone, the left motor has red and blue leads.
    • From the front of the drone, the right motor has white and black leads.
    • Remove the leads from their points on the motherboard with a soldering iron, respective to each motor.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering practices.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 203
