Ga door naar hoofdinhoud
Protocol Slipstream WiFi Propeller Replacement
Wat je nodig hebt
    1. Protocol Slipstream WiFi Propeller Replacement, Propeller: stap 1, afbeelding 1 van 1
      • Remove the 4.5 mm Philips #00 screw that holds the propeller in place.
      Vraag FixBot
      Voeg opmerking toe
    2. Protocol Slipstream WiFi Propeller Replacement: stap 2, afbeelding 1 van 1
      • Lift the propeller off the device
      • Note: When sliding on the new propeller, make sure to align the groove on the propeller with the shaft of the gear. If aligned correctly the propeller should slide on smoothly.
      • There are two different propellers that go on the device. Each propeller has a 3 or 4 written on it. Be sure to replace the propeller with a new propeller with the matching number.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 474
