Inleiding
If your drone does not respond to the controller, the antenna could be the issue. The following guide will help you to replace the antenna in the controller.
Wat je nodig hebt
Remove the six 8.8 mm screws located on the back panel of the controller using a Phillips 000 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
