Ga door naar hoofdinhoud
Protocol Dronium III AP Camera Replacement
Wat je nodig hebt
    1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: stap 1, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement, Drone Battery Pack: stap 1, afbeelding 2 van 2
      • Ensure the drone is powered off.
      • Press in and lift battery compartment cover.
      • A soft pry tool may be used for easier access.
      Vraag FixBot
      Voeg opmerking toe
    2. Protocol Dronium III AP Camera Replacement: stap 2, afbeelding 1 van 1
      • Remove battery pack from body of drone.
      Vraag FixBot
      Voeg opmerking toe
    3. Protocol Dronium III AP Camera Replacement: stap 3, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 3, afbeelding 2 van 2
      • Disconnect white connectors between the battery pack and drone.
      Vraag FixBot
      Voeg opmerking toe
    1. Protocol Dronium III AP Camera Replacement, Camera: stap 4, afbeelding 1 van 1
      • Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Protocol Dronium III AP Camera Replacement: stap 5, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 5, afbeelding 2 van 2
      • Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
      • Remove the Body Cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Protocol Dronium III AP Camera Replacement: stap 6, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 6, afbeelding 2 van 2
      • Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
      • Lift the Motherboard off the mounting position.
      • Do not pull hard on the Motherboard as solder connections are fragile.
      Vraag FixBot
      Voeg opmerking toe
    4. Protocol Dronium III AP Camera Replacement: stap 7, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Remove the tape covering the camera with the tweezers.
      Vraag FixBot
      Voeg opmerking toe
    5. Protocol Dronium III AP Camera Replacement: stap 8, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 8, afbeelding 2 van 2
      • Remove the plastic holding the ribbon cable connector with the tweezers.
      • Be careful with the ribbon cable, it is easy to damage.
      Vraag FixBot
      Voeg opmerking toe
    6. Protocol Dronium III AP Camera Replacement: stap 9, afbeelding 1 van 1
      • Move the ribbon cable out of the way with the Spuger.
      Vraag FixBot
      Voeg opmerking toe
    7. Protocol Dronium III AP Camera Replacement: stap 10, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 10, afbeelding 2 van 2
      • Remove the camera by gently prying it out of the bracket with the spudger.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Steven Mooers
401 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S1-G1, Rose Fall 2017 Lid van UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 487
