Ga door naar hoofdinhoud
ProntoTec Axius Screen Replacement
Wat je nodig hebt
    1. ProntoTec Axius Screen Replacement, Screen: stap 1, afbeelding 1 van 1
      • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
      • Place the tablet face-up on a flat table
      Vraag FixBot
      Voeg opmerking toe
    2. ProntoTec Axius Screen Replacement: stap 2, afbeelding 1 van 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Vraag FixBot
      Voeg opmerking toe
    3. ProntoTec Axius Screen Replacement: stap 3, afbeelding 1 van 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Vraag FixBot
      Voeg opmerking toe
    4. ProntoTec Axius Screen Replacement: stap 4, afbeelding 1 van 1
      • Remove all of the yellow tape that is on the device with the spudger.
      • Be careful not to cut any wires that are under the tapes.
      Vraag FixBot
      Voeg opmerking toe
    5. ProntoTec Axius Screen Replacement: stap 5, afbeelding 1 van 2 ProntoTec Axius Screen Replacement: stap 5, afbeelding 2 van 2
      • Use the flat end of the spudger to gently pry the battery from the back of the screen.
      Vraag FixBot
      Voeg opmerking toe
    6. ProntoTec Axius Screen Replacement: stap 6, afbeelding 1 van 2 ProntoTec Axius Screen Replacement: stap 6, afbeelding 2 van 2
      • Use a spudger to lift all the ribbon cable clamps
      • Detach all three ribbon cables from the clamps
      Vraag FixBot
      Voeg opmerking toe
    7. ProntoTec Axius Screen Replacement: stap 7, afbeelding 1 van 3 ProntoTec Axius Screen Replacement: stap 7, afbeelding 2 van 3 ProntoTec Axius Screen Replacement: stap 7, afbeelding 3 van 3
      • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
      Vraag FixBot
      Voeg opmerking toe
    8. ProntoTec Axius Screen Replacement: stap 8, afbeelding 1 van 3 ProntoTec Axius Screen Replacement: stap 8, afbeelding 2 van 3 ProntoTec Axius Screen Replacement: stap 8, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Heavy-Duty Spudger
      • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
      • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
      Vraag FixBot
      Voeg opmerking toe
    9. ProntoTec Axius Screen Replacement: stap 9, afbeelding 1 van 1
      • Remove the orange tab from the back of the screen as shown in the picture
      Vraag FixBot
      Voeg opmerking toe
    10. ProntoTec Axius Screen Replacement: stap 10, afbeelding 1 van 2 ProntoTec Axius Screen Replacement: stap 10, afbeelding 2 van 2
      • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Antonio Irons
441 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-3, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 610
