Ga door naar hoofdinhoud
ProntoTec Axius Camera Replacement
Wat je nodig hebt
    1. ProntoTec Axius Camera Replacement, Camera: stap 1, afbeelding 1 van 1
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      Vraag FixBot
      Voeg opmerking toe
    2. ProntoTec Axius Camera Replacement: stap 2, afbeelding 1 van 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Vraag FixBot
      Voeg opmerking toe
    3. ProntoTec Axius Camera Replacement: stap 3, afbeelding 1 van 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Vraag FixBot
      Voeg opmerking toe
    4. ProntoTec Axius Camera Replacement: stap 4, afbeelding 1 van 1
      • Remove only the yellow tape that touches the battery.
      • Be careful not to cut or damage the wires (red and black) that are under the yellow tape.'
      Vraag FixBot
      Voeg opmerking toe
    5. ProntoTec Axius Camera Replacement: stap 5, afbeelding 1 van 2 ProntoTec Axius Camera Replacement: stap 5, afbeelding 2 van 2
      • Use the flat end of the spudger to gently pry the top left corner battery from the back of the screen in order to access the camera.
      Vraag FixBot
      Voeg opmerking toe
    6. ProntoTec Axius Camera Replacement: stap 6, afbeelding 1 van 3 ProntoTec Axius Camera Replacement: stap 6, afbeelding 2 van 3 ProntoTec Axius Camera Replacement: stap 6, afbeelding 3 van 3
      • Use the spudger to lift the black clamp as shown in the photo to disconnect the camera from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    7. ProntoTec Axius Camera Replacement: stap 7, afbeelding 1 van 2 ProntoTec Axius Camera Replacement: stap 7, afbeelding 2 van 2
      • Disconet the camera from the motherboard.
      • Pull the camera from the back of the screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Antonio Irons
441 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-3, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 30
Altijd: 458
