Ga door naar hoofdinhoud
ProntoTec Axius Battery Replacement
Wat je nodig hebt
    1. ProntoTec Axius Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table
      Vraag FixBot
      Voeg opmerking toe
    2. ProntoTec Axius Battery Replacement: stap 2, afbeelding 1 van 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Vraag FixBot
      Voeg opmerking toe
    3. ProntoTec Axius Battery Replacement: stap 3, afbeelding 1 van 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Vraag FixBot
      Voeg opmerking toe
    4. ProntoTec Axius Battery Replacement: stap 4, afbeelding 1 van 1
      • Using a spudger remove all the tapes that touches the battery.
      • Be careful not to cute any wires that are under the tapes
      Vraag FixBot
      Voeg opmerking toe
    5. ProntoTec Axius Battery Replacement: stap 5, afbeelding 1 van 1
      • Using a soldering iron, heat up the contact point of the red wire from the battery and the motherboard.
      • When the solder begins to melt, use pliers to gently pull the wire from the motherboard
      • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
      Vraag FixBot
      Voeg opmerking toe
    6. ProntoTec Axius Battery Replacement: stap 6, afbeelding 1 van 1
      • Repeat Step 5 on the black wire connecting the battery to the motherboard as shown in the photo.
      Vraag FixBot
      Voeg opmerking toe
    7. ProntoTec Axius Battery Replacement: stap 7, afbeelding 1 van 2 ProntoTec Axius Battery Replacement: stap 7, afbeelding 2 van 2
      • Using a spudger, gently pry the battery from the back of the screen to remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Antonio Irons
441 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-3, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 604
