Ga door naar hoofdinhoud
Programming the Smart Key
    1. Programming the Smart Key, Enter Settings: stap 1, afbeelding 1 van 1
      • With the Clix on and past the start-up screen, go down to settings.
      • Select it by pressing right.
      Vraag FixBot
      Voeg opmerking toe
    2. Programming the Smart Key, Enter Smart Key: stap 2, afbeelding 1 van 1
      • In settings, go down and press right to select 'Smart Key'.
      Vraag FixBot
      Voeg opmerking toe
    3. Programming the Smart Key, Select an operation: stap 3, afbeelding 1 van 1
      • select the function of your choice by pressing right on anything in the Smart key options menu.
      • The next steps are rundowns of all the operations of the Smart Key.
      Vraag FixBot
      Voeg opmerking toe
    4. Programming the Smart Key, OP-1: Home: stap 4, afbeelding 1 van 1
      • Will send the user straight to the Clix home screen when pressed.
      Vraag FixBot
      Voeg opmerking toe
    5. Programming the Smart Key, OP-2: Play/Pause: stap 5, afbeelding 1 van 1
      • As it says, plays or pauses any music or audio that is playing.
      Vraag FixBot
      Voeg opmerking toe
    6. Programming the Smart Key, OP-3: Shuffle all: stap 6, afbeelding 1 van 1
      • Plays and shuffles all music and audio books when pressed.
      • Note the symbol in the top right of the screen that indicates that it's in shuffle mode.
      Vraag FixBot
      Voeg opmerking toe
    7. Programming the Smart Key, OP-4: Display Orientation: stap 7, afbeelding 1 van 1
      • Rotates the display from landscape to portrait mode, and vice versa when pressed.
      Vraag FixBot
      Voeg opmerking toe
    8. Programming the Smart Key, OP-5: Start/Stop Recording: stap 8, afbeelding 1 van 1
      • Takes the user to the recorder program and automatically starts recording voice.
      Vraag FixBot
      Voeg opmerking toe
    9. Programming the Smart Key, OP-6: Add to Quick List: stap 9, afbeelding 1 van 1
      • when pressed, the Smart Key adds whatever you may be listening to into the Quick List playlist on the Clix.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Now that you know what to do with the Smart Key, you can enjoy the convenience of your selected feature!
Rando_GUY
893 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 350
