Inleiding
This is the battery replacement guide for the Proscan PLT 7050. If you find the need to replace the battery, please follow these steps.
Wat je nodig hebt
Make sure device is unplugged and turned off while working on the device.
Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
Use the soldering tool to remove the wires from the motherboard. (Black and Red)
4 andere personen hebben deze handleiding voltooid.
