Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The techniques of pressing and ironing are often used interchangeably. Both use an iron, but each is a different technique. Ironing is the action of sliding the iron over fabric or a seam. Pressing involves resting the iron directly onto the fabric or seam, holding the iron in place, and then pulling it away. In pressing, there’s no sliding motion. Pressing protects delicate or loosely woven fabrics (such as silk or linen) from getting distorted while removing wrinkles. The ironing motion removes wrinkles from stable fabrics and proves particularly useful on large, single-layered fabrics.Once you’ve decided whether to press or iron your fabric, you’ll need to decide whether or not to steam the fabric as you proceed. Try a dry iron first, and only steam when there’s a stubborn wrinkle. Before steaming, be sure you’re using a fabric that won’t be harmed with water.
Wat je nodig hebt
When ironing a seam, flip the project inside out so the seam is visible.
Slide the fabric over the end of the ironing board, seam side up, so that only one layer of the fabric is ironed at a time.
6 andere personen hebben deze handleiding voltooid.
4 opmerkingen
We read your blog and it is very beautiful and the content is also good, you have well described the fabric well and I liked it so thank you, Linens is a luxurious fabric and it is very soft and people like this linen and it is easy to maintain Unsure how to wash linens it is quite easy to wash it like you can wash it by machine or by hand using detergent and liquid And use normal water to wash it and dry it in the sun.
We read your blog and it is very beautiful and the content is also good, you have well described the types of fabric well and I liked it so thank you, There are many types of fabrics such as cotton, rayon, felt, velvet, wool, jersey, drill, dimity, etc. All these fabrics have their own qualities and properties.
nice to see your blog, but you know what there are different ways to iron different Types of Fabrics
This is a very powerful article. Information given by you on the above topic “Press and Iron Fabrics”is very helpful for those who want to know more about how to iron different types of fabric .Thanks a lot for this wonderful article.
