Ga door naar hoofdinhoud
Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
Wat je nodig hebt
    1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: stap 1, afbeelding 1 van 2 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: stap 1, afbeelding 2 van 2
      • Plug in the tree.
      • Use a Christmas light function tester to check the fuse on a light that is not bright.
      • The red light on the function tester will not light up if the fuse is dead.
      Vraag FixBot
      Voeg opmerking toe
    2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 2, afbeelding 1 van 1
      • Unplug the tree from the outlet.
      Vraag FixBot
      Voeg opmerking toe
    3. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 3, afbeelding 1 van 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 3, afbeelding 2 van 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 3, afbeelding 3 van 3
      • Open the fuse cover, then use a small flathead screwdriver or spudger to carefully remove the fuse.
      Vraag FixBot
      Voeg opmerking toe
    4. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 4, afbeelding 1 van 1
      • Using a continuity tester and the fuse, place both tips of the continuity tester on either side of the fuse.
      • The top light should light up red if the fuse is in working condition. If no light appears, repeat this step with a new fuse.
      Vraag FixBot
      Voeg opmerking toe
    5. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 5, afbeelding 1 van 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 5, afbeelding 2 van 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 5, afbeelding 3 van 3
      • Carefully insert the working fuse back into the tree plug, and put the cover on.
      Vraag FixBot
      Voeg opmerking toe
    6. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 6, afbeelding 1 van 1
      • Plug the tree back into the outlet.
      Vraag FixBot
      Voeg opmerking toe
    7. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: stap 7, afbeelding 1 van 1
      • Using the Christmas light function tester, go back to the same spot you initially checked. If the red light appears, you have successfully replaced the fuse!
      • The red light will appear whether the bulb itself is working or not.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Thank you for using this guide!
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 46
Altijd: 4,613
