Ga door naar hoofdinhoud
PowerLead Puto PLD003 Back Buttons Replacement
Wat je nodig hebt
    1. PowerLead Puto PLD003 Back Buttons Replacement, Side Panel: stap 1, afbeelding 1 van 1
      • Slide the battery eject button open to release the battery door.
      Vraag FixBot
      Voeg opmerking toe
    2. PowerLead Puto PLD003 Back Buttons Replacement: stap 2, afbeelding 1 van 1
      • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
      Vraag FixBot
      Voeg opmerking toe
    3. PowerLead Puto PLD003 Back Buttons Replacement: stap 3, afbeelding 1 van 1
      • Rotate the camera so that the underside is facing up.
      • Remove the four 5 mm Phillips #1 screws.
      Vraag FixBot
      Voeg opmerking toe
    4. PowerLead Puto PLD003 Back Buttons Replacement: stap 4, afbeelding 1 van 1
      • Place the camera on a flat surface, with its underside facing you.
      • Gently pull up on the side panel to remove it from the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: stap 5, afbeelding 1 van 2 PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: stap 5, afbeelding 2 van 2
      • Remove the three 4 mm Phillips #1 screws holding the weight.
      • Remove the weight.
      Vraag FixBot
      Voeg opmerking toe
    2. PowerLead Puto PLD003 Back Buttons Replacement: stap 6, afbeelding 1 van 1
      • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
      Vraag FixBot
      Voeg opmerking toe
    3. PowerLead Puto PLD003 Back Buttons Replacement: stap 7, afbeelding 1 van 1
      • Apply pressure to the back panel, away from the camera to remove.
      Vraag FixBot
      Voeg opmerking toe
    4. PowerLead Puto PLD003 Back Buttons Replacement: stap 8, afbeelding 1 van 2 PowerLead Puto PLD003 Back Buttons Replacement: stap 8, afbeelding 2 van 2
      • Place the back panel so the buttons are facing down and the circuit board is facing up.
      • Remove the three 4 mm Phillips #1 screws holding the circuit board in place.
      Vraag FixBot
      Voeg opmerking toe
    5. PowerLead Puto PLD003 Back Buttons Replacement: stap 9, afbeelding 1 van 1
      • Set aside the circuit board.
      • These nubs are what is currently holding the buttons in place.
      • Carefully apply pressure and remove the set of buttons from the nubs.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 460
