Ga door naar hoofdinhoud
PowerBook G3 Wallstreet Keyboard Replacement
Wat je nodig hebt
  1. PowerBook G3 Wallstreet Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
    Vraag FixBot
    Voeg opmerking toe
  2. PowerBook G3 Wallstreet Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    Vraag FixBot
    Voeg opmerking toe
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Vraag FixBot
    Voeg opmerking toe
  3. PowerBook G3 Wallstreet Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
    Vraag FixBot
    Voeg opmerking toe
  4. PowerBook G3 Wallstreet Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
    Vraag FixBot
    Voeg opmerking toe
  5. PowerBook G3 Wallstreet Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Your laptop should look approximately like this.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
3Gids Commentaar
The first iFixit guide?
ljcool2006 - Antwoord Deel
Yes sir! (text minimum)
guardian10 - Antwoord Deel
Yes yes yes yes
Lol - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 93
Altijd: 22,482
