Ga door naar hoofdinhoud
PowerBook G3 Pismo Power Card Replacement
Wat je nodig hebt
  1. PowerBook G3 Pismo Power Card Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    Vraag FixBot
    Voeg opmerking toe
  2. PowerBook G3 Pismo Power Card Replacement: stap 2, afbeelding 1 van 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    Vraag FixBot
    Voeg opmerking toe
  3. PowerBook G3 Pismo Power Card Replacement: stap 3, afbeelding 1 van 1
    • Your laptop should look approximately like this.
    Vraag FixBot
    Voeg opmerking toe
  4. PowerBook G3 Pismo Power Card Replacement, Heat Shield: stap 4, afbeelding 1 van 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    Vraag FixBot
    Voeg opmerking toe
  5. PowerBook G3 Pismo Power Card Replacement: stap 5, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  6. PowerBook G3 Pismo Power Card Replacement, Airport Card: stap 6, afbeelding 1 van 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    Vraag FixBot
    Voeg opmerking toe
  7. PowerBook G3 Pismo Power Card Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the antenna cable from the Airport card.
    Vraag FixBot
    Voeg opmerking toe
  8. PowerBook G3 Pismo Power Card Replacement, PRAM Battery: stap 8, afbeelding 1 van 1
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
    Vraag FixBot
    Voeg opmerking toe
  9. PowerBook G3 Pismo Power Card Replacement: stap 9, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  10. PowerBook G3 Pismo Power Card Replacement, Heat Sink: stap 10, afbeelding 1 van 1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    Vraag FixBot
    Voeg opmerking toe
  11. PowerBook G3 Pismo Power Card Replacement: stap 11, afbeelding 1 van 1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Vraag FixBot
    Voeg opmerking toe
  12. PowerBook G3 Pismo Power Card Replacement, Processor: stap 12, afbeelding 1 van 1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
    Vraag FixBot
    Voeg opmerking toe
  13. PowerBook G3 Pismo Power Card Replacement: stap 13, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  14. PowerBook G3 Pismo Power Card Replacement, Modem: stap 14, afbeelding 1 van 1
    • Remove the black Torx screw from the right side of the modem.
    • Remove the small black plastic rectangle with four holes.
    Vraag FixBot
    Voeg opmerking toe
  15. PowerBook G3 Pismo Power Card Replacement: stap 15, afbeelding 1 van 1
    • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
    Vraag FixBot
    Voeg opmerking toe
  16. PowerBook G3 Pismo Power Card Replacement: stap 16, afbeelding 1 van 1
    • Disconnect the cable from the right side of the modem.
    Vraag FixBot
    Voeg opmerking toe
  17. PowerBook G3 Pismo Power Card Replacement, Hard Drive: stap 17, afbeelding 1 van 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
    Vraag FixBot
    Voeg opmerking toe
  18. PowerBook G3 Pismo Power Card Replacement: stap 18, afbeelding 1 van 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    Vraag FixBot
    Voeg opmerking toe
  19. PowerBook G3 Pismo Power Card Replacement: stap 19, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  20. PowerBook G3 Pismo Power Card Replacement, Clutch Cover: stap 20, afbeelding 1 van 1
    • Push the display back so that it lies flat.
    • Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
    Vraag FixBot
    Voeg opmerking toe
  21. PowerBook G3 Pismo Power Card Replacement: stap 21, afbeelding 1 van 1
    • Lift the clutch cover up and off, rotating it toward yourself.
    Vraag FixBot
    Voeg opmerking toe
  22. PowerBook G3 Pismo Power Card Replacement, Inverter: stap 22, afbeelding 1 van 1
    • Grasp the orange display data cable and disconnect it from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  23. PowerBook G3 Pismo Power Card Replacement: stap 23, afbeelding 1 van 1
    • Remove the single black Torx screw that fastens the display cable to the plastic casing.
    • Grasp the thin display inverter board at its left end; lift up and rotate toward yourself.
    • There are two tabs that hold the display inverter in place; these are what you need to get past in order to pull the board free.
    Vraag FixBot
    Voeg opmerking toe
  24. PowerBook G3 Pismo Power Card Replacement: stap 24, afbeelding 1 van 1
    • Disconnect the white inverter cable from the right end of the board
    Vraag FixBot
    Voeg opmerking toe
  25. PowerBook G3 Pismo Power Card Replacement: stap 25, afbeelding 1 van 1
    • Disconnect the inverter plug, pulling directly up from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  26. PowerBook G3 Pismo Power Card Replacement, Display: stap 26, afbeelding 1 van 1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black Torx screws.
    Vraag FixBot
    Voeg opmerking toe
  27. PowerBook G3 Pismo Power Card Replacement: stap 27, afbeelding 1 van 1
    • Returning to the front, pull the black Airport antenna up from its recessed housing.
    Vraag FixBot
    Voeg opmerking toe
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
    Vraag FixBot
    Voeg opmerking toe
  28. PowerBook G3 Pismo Power Card Replacement: stap 29, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  29. PowerBook G3 Pismo Power Card Replacement, Upper Case: stap 30, afbeelding 1 van 1
    • Disconnect the wide orange cable that connects the airport card slot to the logic board.
    Vraag FixBot
    Voeg opmerking toe
  30. PowerBook G3 Pismo Power Card Replacement: stap 31, afbeelding 1 van 1
    • Remove the three long silver and one short black Torx screws from the beige plastic casing.
    Vraag FixBot
    Voeg opmerking toe
  31. PowerBook G3 Pismo Power Card Replacement: stap 32, afbeelding 1 van 1
    • Slide the thin plastic shield away from you, out from under the black casing.
    • Disconnect the newly revealed thin orange ribbon from the logic board.
    • Remove the two long silver Torx screws.
    Vraag FixBot
    Voeg opmerking toe
  32. PowerBook G3 Pismo Power Card Replacement: stap 33, afbeelding 1 van 1
    • Turn the laptop over.
    • Remove the five short Torx screws from the bottom casing.
    • Remove the two long Torx screws in the front left and front right corners; make sure to put these back in the proper place when reassembling.
    Vraag FixBot
    Voeg opmerking toe
  33. PowerBook G3 Pismo Power Card Replacement: stap 34, afbeelding 1 van 1
    • Turn the laptop back over.
    • Remove three short black Torx screws from the metal frame.
    • Remove the small Torx screw to the far left that fastens the logic board to the casing.
    Vraag FixBot
    Voeg opmerking toe
  34. PowerBook G3 Pismo Power Card Replacement: stap 35, afbeelding 1 van 1
    • Grasp the upper plastic casing where it locks into the internal frame and pull back. When the plastic tab has cleared the slot that the casing locks into, pull up enough to keep it from locking back into place.
    Vraag FixBot
    Voeg opmerking toe
  35. PowerBook G3 Pismo Power Card Replacement: stap 36, afbeelding 1 van 1
    • The PC card eject button on the laptop's left side prevents the upper casing from lifting up. In order to bypass the button, push it in far enough so that you can pull the upper casing's left side out and up beyond the button.
    Vraag FixBot
    Voeg opmerking toe
  36. PowerBook G3 Pismo Power Card Replacement: stap 37, afbeelding 1 van 1
    • Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cables or you may damage the sound card.
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
    Vraag FixBot
    Voeg opmerking toe
  37. PowerBook G3 Pismo Power Card Replacement: stap 38, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  38. PowerBook G3 Pismo Power Card Replacement, Power Card: stap 39, afbeelding 1 van 1
    • Remove the two long silver Torx screws from the power card in the center of the laptop
    Vraag FixBot
    Voeg opmerking toe
  39. PowerBook G3 Pismo Power Card Replacement: stap 40, afbeelding 1 van 1
    • Grasp the power card near the black shield and lift up.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 44
Altijd: 10,243
