Ga door naar hoofdinhoud
PowerBook G3 Pismo PRAM Battery Replacement
Wat je nodig hebt
    1. PowerBook G3 Pismo PRAM Battery Replacement, Keyboard: stap 1, afbeelding 1 van 1
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
      Vraag FixBot
      Voeg opmerking toe
    2. PowerBook G3 Pismo PRAM Battery Replacement: stap 2, afbeelding 1 van 1
      • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
      • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
      • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
      Vraag FixBot
      Voeg opmerking toe
    3. PowerBook G3 Pismo PRAM Battery Replacement: stap 3, afbeelding 1 van 1
      • Your laptop should look approximately like this.
      Vraag FixBot
      Voeg opmerking toe
    1. PowerBook G3 Pismo PRAM Battery Replacement, Heat Shield: stap 4, afbeelding 1 van 1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
      • Lift the heat shield up and pull it toward you.
      Vraag FixBot
      Voeg opmerking toe
    2. PowerBook G3 Pismo PRAM Battery Replacement: stap 5, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    1. PowerBook G3 Pismo PRAM Battery Replacement, Airport Card: stap 6, afbeelding 1 van 1
      • Skip this step if your computer does not have an Airport card installed.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
      • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
      Vraag FixBot
      Voeg opmerking toe
    2. PowerBook G3 Pismo PRAM Battery Replacement: stap 7, afbeelding 1 van 1
      • Disconnect the antenna cable from the Airport card.
      Vraag FixBot
      Voeg opmerking toe
    1. PowerBook G3 Pismo PRAM Battery Replacement, PRAM Battery: stap 8, afbeelding 1 van 1
      • Pull the battery cable directly up from the logic board.
      • Remove the battery from its holder by pulling up and to the left.
      Vraag FixBot
      Voeg opmerking toe
    2. PowerBook G3 Pismo PRAM Battery Replacement: stap 9, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
Conclusie
27 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
6Gids Commentaar
Frankly speaking I do not have idea why do I need steps 2-7 to replace battery? Why I can't go directly to step 8 if it is possible? BTW - the battery seems to be composed from 4 standard batteries. Is anyone aware how to assembly new battery? It is not available as spare part (616-0108)
Tomek - Antwoord Deel
Agreed, I just successfully removed my PRAM battery skipping all those steps, just popped the keyboard out, removed the DVD drive from the right-hand out and popped that bad boy out, no problemo.
Edward Gain - Antwoord Deel
I read that you "removed the DVD drive from the right-hand out...." I'm baffled as to what you mean or how that is done. Can you explain that step?
Scott Kohanek - Antwoord Deel
Why do I need to remove the airport card? It's just like telling somebody to remove their shoes to take off their hat?
christopher Ng - Antwoord Deel
Wish I had read the comments before proceeding. Just removed the Airport card and put it back in for no reason. Thanks for the instructions though.
j.boersma - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 72
Altijd: 42,200
