Ga door naar hoofdinhoud
PowerBook G3 Lombard Processor Replacement
Wat je nodig hebt
  1. PowerBook G3 Lombard Processor Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
    Vraag FixBot
    Voeg opmerking toe
  2. PowerBook G3 Lombard Processor Replacement: stap 2, afbeelding 1 van 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
    Vraag FixBot
    Voeg opmerking toe
  3. PowerBook G3 Lombard Processor Replacement: stap 3, afbeelding 1 van 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
    Vraag FixBot
    Voeg opmerking toe
  4. PowerBook G3 Lombard Processor Replacement, Heat Shield: stap 4, afbeelding 1 van 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
    Vraag FixBot
    Voeg opmerking toe
  5. PowerBook G3 Lombard Processor Replacement: stap 5, afbeelding 1 van 1
    • Lift the heat shield up and pull it toward you.
    Vraag FixBot
    Voeg opmerking toe
  6. PowerBook G3 Lombard Processor Replacement: stap 6, afbeelding 1 van 1
    • Your laptop should look approximately like this.
    Vraag FixBot
    Voeg opmerking toe
  7. PowerBook G3 Lombard Processor Replacement, PRAM Battery: stap 7, afbeelding 1 van 1
    • Pull the battery cable directly up from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  8. PowerBook G3 Lombard Processor Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery from its holder by pulling up and to the left.
    Vraag FixBot
    Voeg opmerking toe
  9. PowerBook G3 Lombard Processor Replacement, Modem: stap 9, afbeelding 1 van 1
    • Remove the two silver Phillips screws from the modem.
    Vraag FixBot
    Voeg opmerking toe
  10. PowerBook G3 Lombard Processor Replacement: stap 10, afbeelding 1 van 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
    Vraag FixBot
    Voeg opmerking toe
  11. PowerBook G3 Lombard Processor Replacement: stap 11, afbeelding 1 van 1
    • Disconnect the cable from the right side of the modem.
    Vraag FixBot
    Voeg opmerking toe
  12. PowerBook G3 Lombard Processor Replacement: stap 12, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  13. PowerBook G3 Lombard Processor Replacement, Processor: stap 13, afbeelding 1 van 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    Vraag FixBot
    Voeg opmerking toe
  14. PowerBook G3 Lombard Processor Replacement: stap 14, afbeelding 1 van 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
    Vraag FixBot
    Voeg opmerking toe
  15. PowerBook G3 Lombard Processor Replacement: stap 15, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 40
Altijd: 6,386
