Ga door naar hoofdinhoud
PowerBook G3 Lombard PRAM Battery Replacement
Wat je nodig hebt
    1. PowerBook G3 Lombard PRAM Battery Replacement, Keyboard: stap 1, afbeelding 1 van 1
      • Turn the computer so that the ports are facing you.
      • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
      Vraag FixBot
      Voeg opmerking toe
    2. PowerBook G3 Lombard PRAM Battery Replacement: stap 2, afbeelding 1 van 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
      Vraag FixBot
      Voeg opmerking toe
    3. PowerBook G3 Lombard PRAM Battery Replacement: stap 3, afbeelding 1 van 1
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
      • In order to replace the keyboard, you must first remove the modem.
      Vraag FixBot
      Voeg opmerking toe
    1. PowerBook G3 Lombard PRAM Battery Replacement, PRAM Battery: stap 4, afbeelding 1 van 1
      • Pull the battery cable directly up from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    2. PowerBook G3 Lombard PRAM Battery Replacement: stap 5, afbeelding 1 van 1
      • Remove the battery from its holder by pulling up and to the left.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
2Gids Commentaar
Step 4, 5 and 6 are useless for changing the PRAM battery..
Godzil - Antwoord Deel
Seems the step I was referring to are no longer there!
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 50
Altijd: 11,811
