Inleiding
You can install hard drives up to 12.5mm thick.
Wat je nodig hebt
Turn the computer so that the ports are facing you.
If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
Remove the four black Torx screws located at the four corners of the hard drive bracket.
10 andere personen hebben deze handleiding voltooid.
