Ga door naar hoofdinhoud
PowerBook G3 Lombard Display Replacement
Wat je nodig hebt
  1. PowerBook G3 Lombard Display Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
    Vraag FixBot
    Voeg opmerking toe
  2. PowerBook G3 Lombard Display Replacement: stap 2, afbeelding 1 van 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
    Vraag FixBot
    Voeg opmerking toe
  3. PowerBook G3 Lombard Display Replacement: stap 3, afbeelding 1 van 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
    Vraag FixBot
    Voeg opmerking toe
  4. PowerBook G3 Lombard Display Replacement, Heat Shield: stap 4, afbeelding 1 van 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
    Vraag FixBot
    Voeg opmerking toe
  5. PowerBook G3 Lombard Display Replacement: stap 5, afbeelding 1 van 1
    • Lift the heat shield up and pull it toward you.
    Vraag FixBot
    Voeg opmerking toe
  6. PowerBook G3 Lombard Display Replacement: stap 6, afbeelding 1 van 1
    • Your laptop should look approximately like this.
    Vraag FixBot
    Voeg opmerking toe
  7. PowerBook G3 Lombard Display Replacement, PRAM Battery: stap 7, afbeelding 1 van 1
    • Pull the battery cable directly up from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  8. PowerBook G3 Lombard Display Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery from its holder by pulling up and to the left.
    Vraag FixBot
    Voeg opmerking toe
  9. PowerBook G3 Lombard Display Replacement, Modem: stap 9, afbeelding 1 van 1
    • Remove the two silver Phillips screws from the modem.
    Vraag FixBot
    Voeg opmerking toe
  10. PowerBook G3 Lombard Display Replacement: stap 10, afbeelding 1 van 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
    Vraag FixBot
    Voeg opmerking toe
  11. PowerBook G3 Lombard Display Replacement: stap 11, afbeelding 1 van 1
    • Disconnect the cable from the right side of the modem.
    Vraag FixBot
    Voeg opmerking toe
  12. PowerBook G3 Lombard Display Replacement: stap 12, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  13. PowerBook G3 Lombard Display Replacement, Processor: stap 13, afbeelding 1 van 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    Vraag FixBot
    Voeg opmerking toe
  14. PowerBook G3 Lombard Display Replacement: stap 14, afbeelding 1 van 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
    Vraag FixBot
    Voeg opmerking toe
  15. PowerBook G3 Lombard Display Replacement: stap 15, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  16. PowerBook G3 Lombard Display Replacement, RAM: stap 16, afbeelding 1 van 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
    Vraag FixBot
    Voeg opmerking toe
  17. PowerBook G3 Lombard Display Replacement, Hard Drive: stap 17, afbeelding 1 van 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
    Vraag FixBot
    Voeg opmerking toe
  18. PowerBook G3 Lombard Display Replacement: stap 18, afbeelding 1 van 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    Vraag FixBot
    Voeg opmerking toe
  19. PowerBook G3 Lombard Display Replacement, Clutch Cover: stap 19, afbeelding 1 van 1
    • Push the display back so that it lies flat.
    Vraag FixBot
    Voeg opmerking toe
  20. PowerBook G3 Lombard Display Replacement: stap 20, afbeelding 1 van 1
    • Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
    Vraag FixBot
    Voeg opmerking toe
  21. PowerBook G3 Lombard Display Replacement: stap 21, afbeelding 1 van 1
    • Lift the clutch cover up and off, rotating it toward yourself.
    Vraag FixBot
    Voeg opmerking toe
  22. PowerBook G3 Lombard Display Replacement, Inverter: stap 22, afbeelding 1 van 1
    • Grasp the orange display data cable and disconnect it from the logic board.
    • Pull the display cable straight up so that it is vertical.
    Vraag FixBot
    Voeg opmerking toe
  23. PowerBook G3 Lombard Display Replacement: stap 23, afbeelding 1 van 1
    • Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
    • There are two tabs that hold the display inverter in place that you need to get past in order to pull the board free.
    Vraag FixBot
    Voeg opmerking toe
  24. PowerBook G3 Lombard Display Replacement: stap 24, afbeelding 1 van 1
    • Disconnect the white inverter cable connector from the right end of the board.
    Vraag FixBot
    Voeg opmerking toe
  25. PowerBook G3 Lombard Display Replacement: stap 25, afbeelding 1 van 1
    • Disconnect the inverter plug, pulling directly up from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  26. PowerBook G3 Lombard Display Replacement: stap 26, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  27. PowerBook G3 Lombard Display Replacement, Display: stap 27, afbeelding 1 van 1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black Torx screws.
    Vraag FixBot
    Voeg opmerking toe
  28. PowerBook G3 Lombard Display Replacement: stap 28, afbeelding 1 van 1
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
    Vraag FixBot
    Voeg opmerking toe
  29. PowerBook G3 Lombard Display Replacement: stap 29, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 52
Altijd: 9,011
