Ga door naar hoofdinhoud
PowerBook 3400 M3553 Keyboard Replacement
Wat je nodig hebt
  1. PowerBook 3400 M3553 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
    Vraag FixBot
    Voeg opmerking toe
  2. PowerBook 3400 M3553 Keyboard Replacement: stap 2, afbeelding 1 van 2 PowerBook 3400 M3553 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Hold the button on the front left side and slide the battery out.
    Vraag FixBot
    Voeg opmerking toe
  3. PowerBook 3400 M3553 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
    Vraag FixBot
    Voeg opmerking toe
  4. PowerBook 3400 M3553 Keyboard Replacement: stap 4, afbeelding 1 van 3 PowerBook 3400 M3553 Keyboard Replacement: stap 4, afbeelding 2 van 3 PowerBook 3400 M3553 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
    Vraag FixBot
    Voeg opmerking toe
  5. PowerBook 3400 M3553 Keyboard Replacement: stap 5, afbeelding 1 van 2 PowerBook 3400 M3553 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Michael Mondragon
397 Reputatie
9 handleidingen geschreven
Cal Poly, Team 24-59, Amido Spring 2011 Lid van Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 31
Altijd: 2,754
