Ga door naar hoofdinhoud
PowerBook 3400 M3553 Display Replacement
Wat je nodig hebt
  1. PowerBook 3400 M3553 Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
    Vraag FixBot
    Voeg opmerking toe
  2. PowerBook 3400 M3553 Display Replacement: stap 2, afbeelding 1 van 2 PowerBook 3400 M3553 Display Replacement: stap 2, afbeelding 2 van 2
    • Hold the button on the front left side and slide the battery out.
    Vraag FixBot
    Voeg opmerking toe
  3. PowerBook 3400 M3553 Display Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
    Vraag FixBot
    Voeg opmerking toe
  4. PowerBook 3400 M3553 Display Replacement: stap 4, afbeelding 1 van 3 PowerBook 3400 M3553 Display Replacement: stap 4, afbeelding 2 van 3 PowerBook 3400 M3553 Display Replacement: stap 4, afbeelding 3 van 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
    Vraag FixBot
    Voeg opmerking toe
  5. PowerBook 3400 M3553 Display Replacement: stap 5, afbeelding 1 van 2 PowerBook 3400 M3553 Display Replacement: stap 5, afbeelding 2 van 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
    Vraag FixBot
    Voeg opmerking toe
  6. PowerBook 3400 M3553 Display Replacement, RAM: stap 6, afbeelding 1 van 2 PowerBook 3400 M3553 Display Replacement, RAM: stap 6, afbeelding 2 van 2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
    Vraag FixBot
    Voeg opmerking toe
  7. PowerBook 3400 M3553 Display Replacement, Speaker Panel: stap 7, afbeelding 1 van 2 PowerBook 3400 M3553 Display Replacement, Speaker Panel: stap 7, afbeelding 2 van 2
    • Disconnect the wires from the port.
    Vraag FixBot
    Voeg opmerking toe
  8. PowerBook 3400 M3553 Display Replacement: stap 8, afbeelding 1 van 1
    • Remove the 7mm screw connecting the speaker panel to the computer.
    Vraag FixBot
    Voeg opmerking toe
  9. PowerBook 3400 M3553 Display Replacement: stap 9, afbeelding 1 van 2 PowerBook 3400 M3553 Display Replacement: stap 9, afbeelding 2 van 2
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
    Vraag FixBot
    Voeg opmerking toe
  10. PowerBook 3400 M3553 Display Replacement: stap 10, afbeelding 1 van 2 PowerBook 3400 M3553 Display Replacement: stap 10, afbeelding 2 van 2
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
    Vraag FixBot
    Voeg opmerking toe
  11. PowerBook 3400 M3553 Display Replacement, Display: stap 11, afbeelding 1 van 1
    • Remove the panels on either side by gently but firmly pulling up on them with both hands.
    Vraag FixBot
    Voeg opmerking toe
  12. PowerBook 3400 M3553 Display Replacement: stap 12, afbeelding 1 van 2 PowerBook 3400 M3553 Display Replacement: stap 12, afbeelding 2 van 2
    • Gently pull up on the ribbon cable connection that connects the screen to the logic board.
    Vraag FixBot
    Voeg opmerking toe
  13. PowerBook 3400 M3553 Display Replacement: stap 13, afbeelding 1 van 2 PowerBook 3400 M3553 Display Replacement: stap 13, afbeelding 2 van 2
    • The two T8 13 mm torx screws hold the display screen in place. Be sure to remove the screws while supporting the screen or else it will fall.
    • Remove the two T8 13 mm long torx screws on either side of the display, located under the side panels.
    • Gently pull the display free of the computer.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To replace the display, follow these instructions in reverse order.
Michael Mondragon
397 Reputatie
9 handleidingen geschreven
Cal Poly, Team 24-59, Amido Spring 2011 Lid van Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Leden
18 handleidingen geschreven
2Gids Commentaar
Note that the side panels should be placed back BEFORE the audio panel.
Stanislav Ambartsumov - Antwoord Deel
right, also I often had problems with placing the audio panel back into its place, it's three little plastic noses just didnt want to fit back into its notches of the back.
Jamba - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 50
Altijd: 3,697
