Inleiding
The PowerBook 180 was one of Apple's top of the line notebook computers at around 1993. It was in high demand through all of its life, and had a selling price of about $3900 base model. This computer can run System 7 - 8.1 (through Born Again) and has a 68030 processor running at 33mhz.
Wat je nodig hebt
The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
Slide the battery door to the front of the computer, as directed by the arrows.
Pull out the battery.
Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
3 andere personen hebben deze handleiding voltooid.
