Ga door naar hoofdinhoud
PowerA Spectra Infinity Enhanced Bumpers Replacement
Wat je nodig hebt
  1. PowerA Spectra Infinity Enhanced Bumpers Replacement, Motherboard: stap 1, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Bumpers Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Flip the controller so the back is facing up.
    Vraag FixBot
    Voeg opmerking toe
  2. PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 3, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 3, afbeelding 2 van 2
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
    Vraag FixBot
    Voeg opmerking toe
  4. PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 4, afbeelding 1 van 1
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 5, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 5, afbeelding 2 van 2
    • Use your hand to separate the motherboard from the face plate.
    Vraag FixBot
    Voeg opmerking toe
  6. PowerA Spectra Infinity Enhanced Bumpers Replacement, Bumpers: stap 6, afbeelding 1 van 1
    • Remove two 10 mm screws holding the bumper to the faceplate using a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 7, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 7, afbeelding 2 van 2
    • Remove the single 7.9 mm screw holding the bumpers to the faceplate using a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. PowerA Spectra Infinity Enhanced Bumpers Replacement: stap 8, afbeelding 1 van 1
    • Remove the freed bumpers from the faceplate.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kevyn Jorge
1.018 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 6-5, Botvin Spring 2024 Lid van UMass Dartmouth, Team 6-5, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G5
3 Leden
12 handleidingen geschreven
3Gids Commentaar
okay but where can I get a replacement part from, I've spent ages looking and cant find one anywhere
Tom Radda - Antwoord Deel
Do you sell replacement parts?
Everett - Antwoord Deel
Replacement bumpers link?
Daniel Skerritt - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 79
Altijd: 2,262
