Ga door naar hoofdinhoud
PowerA Spectra Controller Buttons Replacement
Wat je nodig hebt
  1. PowerA Spectra Controller Buttons Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Flip the controller over so the backplate is facing up.
  2. PowerA Spectra Controller Buttons Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #2 screwdriver to remove the eight 7.8 mm screws that secure the rear case.
  3. PowerA Spectra Controller Buttons Replacement: stap 3, afbeelding 1 van 1
    • Hold the front case in one hand and pull the rear case off.
  4. PowerA Spectra Controller Buttons Replacement, Buttons: stap 4, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 7.8 mm screws securing the motherboard to the chassis.
  5. PowerA Spectra Controller Buttons Replacement: stap 5, afbeelding 1 van 1
    • Pull the motherboard away from the controller to access the buttons.
    • The motherboard is not fully removable because it is attached to the D-Pad. Be careful not to rip the motherboard from the D-Pad.
  6. PowerA Spectra Controller Buttons Replacement: stap 6, afbeelding 1 van 1
    • Pull the old buttons out of the shell of the controller using the angled tweezers.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Mallorie Barton
409 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 159
