Ga door naar hoofdinhoud
PowerA Fusion Controller For Xbox One Analog Stick Replacement
Wat je nodig hebt
  1. PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: stap 1, afbeelding 1 van 3 PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: stap 1, afbeelding 2 van 3 PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: stap 1, afbeelding 3 van 3
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Lift off the two bottom grip covers of the controller.
  2. PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 2, afbeelding 1 van 2 PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 2, afbeelding 2 van 2
    • Remove the remaining (2) two 9.2mm screws holding the back cover with a JIS #1 screwdriver.
    • Carefully lift and remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 3, afbeelding 1 van 3 PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 3, afbeelding 2 van 3 PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 3, afbeelding 3 van 3
    • Carefully remove the (5) five 9.2mm screws holding the motherboard with a JIS #1 screwdriver.
    • Lift the motherboard and rest it face up to the right of the controller front plate.
  4. PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 4, afbeelding 1 van 2 PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 4, afbeelding 2 van 2
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Remove the motherboard from the face plate of the controller.
  5. PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 5, afbeelding 1 van 2 PowerA Fusion Controller For Xbox One Analog Stick Replacement: stap 5, afbeelding 2 van 2
    • Use the tweezers to unclip the (4) four metal teeth of the analog stick.
    • Use the soldering iron and desoldering braid to desolder the analog stick sensor module from the back of the motherboard.
    • Place the new analog stick sensor module and solder it back.
    • Use the Hoe moet je (de-)solderen? guide on iFixit to help in desoldering and soldering the analog stick sensor module.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Marjan Mehedi
173 Reputatie
1 Handleiding geschreven
USF Tampa, Team S14-G4, Boczar Fall 2017 Lid van USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Leden
5 handleidingen geschreven
3 opmerkingen
Hi I’m looking those analog stick but I’m only finding the plastic and they are to big they are called different or something ?
Jose nobkes - Antwoord
Have you found a replacement yet? I ran into the same problem a couple of months ago, the potenciometers that I ordered did not fit into the motherboard. I even tried some other ones from a generic USB controler to no avail. Manufacturers do not report the sizes of the potenciometers, so it’s a bet everytime. I yet have to find a potentiometer that fits…
Franco Valdés -
Any joy on purchasing these
Mike Jones -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 70
Altijd: 15,033
