Inleiding
In order for you to remove components with power supplied to them, you need to remove the power from the device by disconnecting from the main power source.
Wat je nodig hebt
Place the device on a firm surface with the device screen facing down.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Using a plastic tool and the plastic card, gently pry off the back cover.
Één andere persoon heeft deze handleiding voltooid.
