Ga door naar hoofdinhoud
Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement
Wat je nodig hebt
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: stap 1, afbeelding 1 van 3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: stap 1, afbeelding 2 van 3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: stap 1, afbeelding 3 van 3
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Screws to Base Plate: stap 2, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: stap 3, afbeelding 1 van 3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: stap 3, afbeelding 2 van 3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: stap 3, afbeelding 3 van 3
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
  4. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing the Screws from the Charger Plate: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two 5mm screws from the metal plate.
  5. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing the Plate: stap 5, afbeelding 1 van 1
    • Grip the metal plate and pull towards you.
    • You may need to wiggle the plate back and forth gently to loosen it from its housing.
  6. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Screw from Base Cover: stap 6, afbeelding 1 van 1
    • Use the Philips #00 screwdriver to remove the four 6mm screws from the base cover.
  7. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Separating Charge Plate from Base Cover: stap 7, afbeelding 1 van 1
    • Gently pull the charge plate away from the rest of the base and separate the two pieces of the charge plate.
  8. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Glue from Wires: stap 8, afbeelding 1 van 2 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Glue from Wires: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the spudger to gently scrape the glue away from the wire connections.
    • If the spudger is not adequate, try using the tweezers to pull the glue away before scraping.
  9. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Desoldering the Wire Connections: stap 9, afbeelding 1 van 1
    • Use the soldering station to desolder the wire connections.
    • For further instructions on using the soldering station click here.
Conclusie
Jay Gunter
378 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 201
