Ga door naar hoofdinhoud
Polycom SoundStation Microphone Replacement
Wat je nodig hebt
    1. Polycom SoundStation Microphone Replacement, Back Housing: stap 1, afbeelding 1 van 1
      • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
      • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
      Vraag FixBot
      Voeg opmerking toe
    2. Polycom SoundStation Microphone Replacement: stap 2, afbeelding 1 van 2 Polycom SoundStation Microphone Replacement: stap 2, afbeelding 2 van 2
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
      Vraag FixBot
      Voeg opmerking toe
    1. Polycom SoundStation Microphone Replacement, Microphone: stap 3, afbeelding 1 van 1
      • Gently remove the yellow padding that covers the red and gray microphone wire on each phone leg.
      Vraag FixBot
      Voeg opmerking toe
    2. Polycom SoundStation Microphone Replacement: stap 4, afbeelding 1 van 2 Polycom SoundStation Microphone Replacement: stap 4, afbeelding 2 van 2
      • Gently pull up on the black plastic tab connected to the motherboard to disconnect each microphone.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cali Nowak Credit
431 Reputatie
4 handleidingen geschreven
2Gids Commentaar
Does anyone know where to purchase replacement microphones for Soundstation 100's? And if replacing mic's does not resolve the problem, are there any other solutions to address the issue of one's voice starting to drop out after about 10 minutes into a call? Thx
working ideas - Antwoord Deel
I encountered an older version. Padding pieces are black. Microphones soldered on board with black & red wires, no plastic tab to disconnect
Putting the thing back together proved to be a challenge : the little display came apart and started shifting all over. Getting that one aligned inside while closing the thing with my fat fingers… . Nasty.
Hans Deseure - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 2,528
