Ga door naar hoofdinhoud
Polycom SoundStation Back Housing Replacement
Wat je nodig hebt
    1. Polycom SoundStation Back Housing Replacement, Back Housing: stap 1, afbeelding 1 van 1
      • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
      • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
      Vraag FixBot
      Voeg opmerking toe
    2. Polycom SoundStation Back Housing Replacement: stap 2, afbeelding 1 van 2 Polycom SoundStation Back Housing Replacement: stap 2, afbeelding 2 van 2
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Cali Nowak Credit
431 Reputatie
4 handleidingen geschreven
1Gids Commentaar
thanks for this - the 7mm were under footpads so I couldn’t see them. cover now off, keyboard dried of coffee and working fine again!!
J M - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 1,554
