Ga door naar hoofdinhoud
Polk MagniFi Soundbar Internal Power Adapter Replacement
Wat je nodig hebt
    1. Polk MagniFi Soundbar Internal Power Adapter Replacement, Internal Power Adapter: stap 1, afbeelding 1 van 1
      • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips' head in size J1.
      • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed. This will be shown in the next step.
      • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
      Vraag FixBot
      Voeg opmerking toe
    2. Polk MagniFi Soundbar Internal Power Adapter Replacement: stap 2, afbeelding 1 van 2 Polk MagniFi Soundbar Internal Power Adapter Replacement: stap 2, afbeelding 2 van 2
      • Underneath the back cover, there will be two flat panels, each with two 1cm screws.
      • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Polk MagniFi Soundbar Internal Power Adapter Replacement: stap 3, afbeelding 1 van 2 Polk MagniFi Soundbar Internal Power Adapter Replacement: stap 3, afbeelding 2 van 2
      • To detach the cables grab the internal power adapter in one hand and with the other grab the base of the wires and firmly pull them straight out from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
[deleted]
695 Reputatie
4 handleidingen geschreven
2Gids Commentaar
where do you get the motherboard for this soundbar?
Tim - Antwoord Deel
Where do we get replacement part?
Leon Haddrell - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 53
Altijd: 2,990
