Inleiding
The power button on the PTAB7XC is made of plastic and frequently breaks; luckily, replacing the power button is a quick and easy process for even beginners.
Wat je nodig hebt
Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver by turning them counterclockwise.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers to push on the side of the black plastic power button that is outside of the device case until the button is as far in as possible.
Pull on the part of the broken power button that is exposed on the inside of the device case using tweezers until the button itself comes loose of the case.
