Ga door naar hoofdinhoud
Polaroid PTAB7XC Motherboard Replacement
Wat je nodig hebt
  1. Polaroid PTAB7XC Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Polaroid PTAB7XC Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver to turn them counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC Motherboard Replacement: stap 2, afbeelding 1 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 2, afbeelding 2 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • Lift the device off of the case and flip over the device so that it sits screen side down.
    • The device is now free from the plastic casing.
    • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
  3. Polaroid PTAB7XC Motherboard Replacement: stap 3, afbeelding 1 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 3, afbeelding 2 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Set the device on a heat safe surface.
    • Desolder from the motherboard the red wire that connects to the battery unit.
    • Desolder from the motherboard the black wire that connects to the battery unit.
    • If either of the wires do not come completely free when desoldering, use tweezers to gently pull them free.
  4. Polaroid PTAB7XC Motherboard Replacement: stap 4, afbeelding 1 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 4, afbeelding 2 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Desolder the following components from the motherboard.
    • Desolder from the motherboard the red wire that connects to the speaker unit.
    • Desolder from the motherboard the black wire that connects to the speaker unit.
    • Desolder from the motherboard the gray wire that runs along the edge of the device.
    • The motherboard will now be detached from any wires connecting to the device.
    • If any of the wires do not detach completely during the desoldering process, then gently pull them off using tweezers.
  5. Polaroid PTAB7XC Motherboard Replacement: stap 5, afbeelding 1 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 5, afbeelding 2 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard
    • Use a small plastic opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
    • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
    • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
    • The motherboard will now be detached from any ribbon cables connecting to the device.
  6. Polaroid PTAB7XC Motherboard Replacement: stap 6, afbeelding 1 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 6, afbeelding 2 van 3 Polaroid PTAB7XC Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning them counterclockwise.
  7. Polaroid PTAB7XC Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Using your index finger and thumb, lift the motherboard out of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 417
