Ga door naar hoofdinhoud
Polaroid Automatic 100 Bottom Frame Spring Replacement
Wat je nodig hebt
    1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: stap 1, afbeelding 1 van 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: stap 1, afbeelding 2 van 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: stap 1, afbeelding 3 van 3
      • Fully extend the bellows to prevent collapse using the #1 tab.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      Vraag FixBot
      Voeg opmerking toe
    2. Polaroid Automatic 100 Bottom Frame Spring Replacement: stap 2, afbeelding 1 van 1
      • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
      Vraag FixBot
      Voeg opmerking toe
    3. Polaroid Automatic 100 Bottom Frame Spring Replacement: stap 3, afbeelding 1 van 1
      • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Polaroid Automatic 100 Bottom Frame Spring Replacement: stap 4, afbeelding 1 van 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: stap 4, afbeelding 2 van 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: stap 4, afbeelding 3 van 3
      • Remove the spring from the shutter mount.
      • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
      • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Katie Miller
680 Reputatie
5 handleidingen geschreven
Cal Poly, Team 4-3, Maness Spring 2015 Lid van Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Leden
26 handleidingen geschreven
2Gids Commentaar
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Antwoord Deel
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 40
Altijd: 1,579
