Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Begin by having the side with volume and power button face up towards you.
Insert a plastic opening tool between the display and the back cover.
Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
Take off yellow tapes that are surrounding the motherboard.
Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
Use the same soldering tool to unsolder the ground wire.
Gently lift the motherboard up and out of the device.
Één andere persoon heeft deze handleiding voltooid.
