Ga door naar hoofdinhoud
Polaroid A10 LCD Replacement
Wat je nodig hebt
  1. Polaroid A10 LCD Replacement, Back Cover: stap 1, afbeelding 1 van 3 Polaroid A10 LCD Replacement, Back Cover: stap 1, afbeelding 2 van 3 Polaroid A10 LCD Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 LCD Replacement, Battery: stap 2, afbeelding 1 van 3 Polaroid A10 LCD Replacement, Battery: stap 2, afbeelding 2 van 3 Polaroid A10 LCD Replacement, Battery: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 LCD Replacement: stap 3, afbeelding 1 van 3 Polaroid A10 LCD Replacement: stap 3, afbeelding 2 van 3 Polaroid A10 LCD Replacement: stap 3, afbeelding 3 van 3
  4. Polaroid A10 LCD Replacement: stap 4, afbeelding 1 van 1
    • Gently lift the battery up and out of the device.
  5. Polaroid A10 LCD Replacement, Front/Back Camera: stap 5, afbeelding 1 van 1
    • The camera head is located on the upper middle section of the device, close to the battery.
  6. Polaroid A10 LCD Replacement: stap 6, afbeelding 1 van 2 Polaroid A10 LCD Replacement: stap 6, afbeelding 2 van 2
    • Start by locating the two left and right screws which hold the camera head in place.
    • Using the Phillip's 000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
  7. Polaroid A10 LCD Replacement: stap 7, afbeelding 1 van 3 Polaroid A10 LCD Replacement: stap 7, afbeelding 2 van 3 Polaroid A10 LCD Replacement: stap 7, afbeelding 3 van 3
    • Locate the camera ribbon cable that is connected to the motherboard.
    • With a spudger, remove the camera ribbon cable base from the motherboard connector.
    • With one finger, delicately remove the camera ribbon cable by sliding down.
  8. Polaroid A10 LCD Replacement, Speakers: stap 8, afbeelding 1 van 1
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  9. Polaroid A10 LCD Replacement: stap 9, afbeelding 1 van 3 Polaroid A10 LCD Replacement: stap 9, afbeelding 2 van 3 Polaroid A10 LCD Replacement: stap 9, afbeelding 3 van 3
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  10. Polaroid A10 LCD Replacement: stap 10, afbeelding 1 van 1
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  11. Polaroid A10 LCD Replacement: stap 11, afbeelding 1 van 1
    • Gently lift the speakers up and out of the device.
  12. Polaroid A10 LCD Replacement, Motherboard: stap 12, afbeelding 1 van 3 Polaroid A10 LCD Replacement, Motherboard: stap 12, afbeelding 2 van 3 Polaroid A10 LCD Replacement, Motherboard: stap 12, afbeelding 3 van 3
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  13. Polaroid A10 LCD Replacement: stap 13, afbeelding 1 van 3 Polaroid A10 LCD Replacement: stap 13, afbeelding 2 van 3 Polaroid A10 LCD Replacement: stap 13, afbeelding 3 van 3
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  14. Polaroid A10 LCD Replacement: stap 14, afbeelding 1 van 2 Polaroid A10 LCD Replacement: stap 14, afbeelding 2 van 2
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
  15. Polaroid A10 LCD Replacement: stap 15, afbeelding 1 van 3 Polaroid A10 LCD Replacement: stap 15, afbeelding 2 van 3 Polaroid A10 LCD Replacement: stap 15, afbeelding 3 van 3
    • Gently lift the motherboard up and out of the device.
  16. Polaroid A10 LCD Replacement, LCD: stap 16, afbeelding 1 van 1
    • Before continuing with the following steps, make sure the battery, camera, speakers, and motherboard are all removed before this procedure.
  17. Polaroid A10 LCD Replacement: stap 17, afbeelding 1 van 3 Polaroid A10 LCD Replacement: stap 17, afbeelding 2 van 3 Polaroid A10 LCD Replacement: stap 17, afbeelding 3 van 3
    • Hold the outer plastic rim (the black plastic that holds the LCD display in place), as shown in the first picture.
    • Use your hand that is holding the device and start by pushing the glass screen upwards from the back with your fingers while pulling the outer plastic rim downwards from the display with your thumb.
    • Using your free hand, use the flat end of the spudger to pry apart the clips holding the LCD screen in place.
    • To release the clips, maintain continuous pressure on the display by gradually holding up the display.
  18. Polaroid A10 LCD Replacement, Screen Is Now Disconnected: stap 18, afbeelding 1 van 1
    • Gently separate the LCD panel from the digitizer.
Conclusie
Shilpa Verma
353 Reputatie
3 handleidingen geschreven
UW Tacoma, Team 3-3, Rose Winter 2015 Lid van UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Leden
12 handleidingen geschreven
1Gids Commentaar
Donde puedo comprar la refacción de touch?
mordecai mordecai - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 2,543
