Ga door naar hoofdinhoud
Polaroid A10 Battery Replacement
Wat je nodig hebt
  1. Polaroid A10 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Polaroid A10 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Polaroid A10 Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Battery Replacement, Battery: stap 2, afbeelding 1 van 3 Polaroid A10 Battery Replacement, Battery: stap 2, afbeelding 2 van 3 Polaroid A10 Battery Replacement, Battery: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 Battery Replacement: stap 3, afbeelding 1 van 3 Polaroid A10 Battery Replacement: stap 3, afbeelding 2 van 3 Polaroid A10 Battery Replacement: stap 3, afbeelding 3 van 3
  4. Polaroid A10 Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently lift the battery up and out of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
armando
150 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 3-3, Rose Winter 2015 Lid van UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 726
