Ga door naar hoofdinhoud
Polar V800 Motherboard Replacement
Wat je nodig hebt
  1. Polar V800 Motherboard Replacement, Waterproofing Seal: stap 1, afbeelding 1 van 2 Polar V800 Motherboard Replacement, Waterproofing Seal: stap 1, afbeelding 2 van 2
    • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
    • Ensure your Polar V800 sports watch is powered off before continuing.
    • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
  2. Polar V800 Motherboard Replacement: stap 2, afbeelding 1 van 3 Polar V800 Motherboard Replacement: stap 2, afbeelding 2 van 3 Polar V800 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Gently separate the watch housing from the back panel.
    • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
  3. Polar V800 Motherboard Replacement: stap 3, afbeelding 1 van 2 Polar V800 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
    • Remove the waterproofing seal.
    • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
  4. Polar V800 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 3 Polar V800 Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 3 Polar V800 Motherboard Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Though not necessary, following the Polar V800 Display Replacement first may make the motherboard easier to remove.
    • Remove the nine, 4.0 millimeter-long screws with a T5 head-type torque screwdriver.
  5. Polar V800 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Once all of the screws have been removed, lift the motherboard to expose the battery beneath motherboard.
    • A red wire and a black wire should run between the motherboard and the battery.
  6. Polar V800 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • The battery is glued down to the back of the watch. It may take some force to detach the battery at the glue joint.
    • Use a spudger to pry the battery from the back of the watch.
    • If your battery is swollen, be very careful in removing the battery. If the packaging is ruptured, the battery will be unsafe to handle with bare hands. The contents of the battery are hazardous.
  7. Polar V800 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Gently pull the wires from their solder joints to disconnect them from the body of the watch.
    • If the wires do not come off easily, you may need to desolder the connections. Visit Hoe moet je (de-)solderen? for more help on soldering.
    • To reconnect the wires to their solder joints, they must be soldered on. See the guide linked above for more guidance.
Conclusie
Jarod Lyles
833 Reputatie
5 handleidingen geschreven
Cal Poly, Team S17-G6, Livingston Spring 2018 Lid van Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Leden
8 handleidingen geschreven
2 opmerkingen
Where can the replacement motherboard be bought? Thanks
Randall - Antwoord
Bonjour et merci pour ses photos ezt explication, mais savez vous ou commander le joint rouge entourant et faisant l “ étanchéité de celle ci. Merci
facebook - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 1,652
