Ga door naar hoofdinhoud
Polar M400 Watch Battery Replacement
Wat je nodig hebt
    1. Polar M400 Watch Battery Replacement, Wrist Strap: stap 1, afbeelding 1 van 1
      • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
      Vraag FixBot
      Voeg opmerking toe
    2. Polar M400 Watch Battery Replacement: stap 2, afbeelding 1 van 2 Polar M400 Watch Battery Replacement: stap 2, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Apply an upward pressure to the holes until the locking pins release.
      • Use precision tweezers to remove the pins that connect the face with the strap.
      Vraag FixBot
      Voeg opmerking toe
    3. Polar M400 Watch Battery Replacement: stap 3, afbeelding 1 van 1
      • Once the pins are released, the old wrist strap should snap off.
      • Simply lock the new wrist strap into place.
      Vraag FixBot
      Voeg opmerking toe
    1. Polar M400 Watch Battery Replacement, Battery: stap 4, afbeelding 1 van 1
      • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
      Vraag FixBot
      Voeg opmerking toe
    2. Polar M400 Watch Battery Replacement: stap 5, afbeelding 1 van 2 Polar M400 Watch Battery Replacement: stap 5, afbeelding 2 van 2
      • Gently remove the backing from the watch.
      Vraag FixBot
      Voeg opmerking toe
    3. Polar M400 Watch Battery Replacement: stap 6, afbeelding 1 van 2 Polar M400 Watch Battery Replacement: stap 6, afbeelding 2 van 2
      • Use tweezers to gently pry the golden sensor away from the battery.
      • Remove battery using the plastic opening tools.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
16 andere personen hebben deze handleiding voltooid.
Nicholas Sanders
543 Reputatie
2 handleidingen geschreven
25Gids Commentaar
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Antwoord Deel
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman - Antwoord Deel
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Antwoord Deel
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Antwoord Deel
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 152
Altijd: 36,403
