Ga door naar hoofdinhoud
Pokewalker Button Replacement
Wat je nodig hebt
  1. Pokewalker Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the Screw on the Back of the Pokewalker.
    Vraag FixBot
    Voeg opmerking toe
  2. Pokewalker Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
    Vraag FixBot
    Voeg opmerking toe
  3. Pokewalker Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the Rear Cover from the Device
    Vraag FixBot
    Voeg opmerking toe
  4. Pokewalker Button Replacement: stap 4, afbeelding 1 van 1
    • Use the flat end of a Spudger to Remove the Battery
    Vraag FixBot
    Voeg opmerking toe
    • Locate the 4 Screws Around the Device
    Vraag FixBot
    Voeg opmerking toe
    • Remove all 4 screws with a Y0 Triwing Screwdriver
    Vraag FixBot
    Voeg opmerking toe
    • Separate the 2 halves of the Device
    • Do not Separate Completely as the Display is Still Connected by a Ribbon Cable
    Vraag FixBot
    Voeg opmerking toe
  5. Gereedschap gebruikt in deze stap:
    • Use a Spudger to Flip the Latch holding the ribbon cable in place and use Tweezers to Pull it out
    • Do not use Excessive force when reinserting the cable, because ribbon cables are fragile
    Vraag FixBot
    Voeg opmerking toe
    • Remove the Rubber-button thingy from the upper case
    • I have no idea what that thing is, edit this guide if you do.
    Vraag FixBot
    Voeg opmerking toe
    • Remove the 3 Plastic Buttons from the Case
    • It helps that the buttons only go in one way, makes it easier to reassemble
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Winni Stuart
447 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 57
Altijd: 1,234
