Ga door naar hoofdinhoud
PlayStation Vita Start/Select Button Replacement
Wat je nodig hebt
  1. PlayStation Vita Start/Select Button Replacement, Case Separation: stap 1, afbeelding 1 van 2 PlayStation Vita Start/Select Button Replacement, Case Separation: stap 1, afbeelding 2 van 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Start/Select Button Replacement: stap 2, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement: stap 2, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement: stap 2, afbeelding 3 van 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Start/Select Button Replacement: stap 3, afbeelding 1 van 2 PlayStation Vita Start/Select Button Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Start/Select Button Replacement: stap 4, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement: stap 4, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement: stap 4, afbeelding 3 van 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Start/Select Button Replacement: stap 5, afbeelding 1 van 2 PlayStation Vita Start/Select Button Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Antwoord
  6. PlayStation Vita Start/Select Button Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Start/Select Button Replacement: stap 7, afbeelding 1 van 1
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Antwoord
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Antwoord
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Antwoord
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Antwoord
    broke the white part
    Benaya Miller - Antwoord
  8. PlayStation Vita Start/Select Button Replacement: stap 8, afbeelding 1 van 1
    • Separate the front and rear cases.
  9. PlayStation Vita Start/Select Button Replacement, Wireless Card: stap 9, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement, Wireless Card: stap 9, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement, Wireless Card: stap 9, afbeelding 3 van 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
    Step 9-11 only apply to the 3G version of the PS Vita.
    logicj83 - Antwoord
    Hello, I have the PCH-2001 model of the PS vita and the right analog stick went out. I ordered a replacement and the stick is slightly larger than the original. The original has a black rectangle on the back, the new version has the star version, which is what you have on this website as the replacement part. Any help here would be much appreciated. Thanks.
    Ben Ragains - Antwoord
    Can I install a WiFi motherboard on a 3g ps vita model 1100?
    fmind11 - Antwoord
  10. PlayStation Vita Start/Select Button Replacement: stap 10, afbeelding 1 van 2 PlayStation Vita Start/Select Button Replacement: stap 10, afbeelding 2 van 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Start/Select Button Replacement: stap 11, afbeelding 1 van 2 PlayStation Vita Start/Select Button Replacement: stap 11, afbeelding 2 van 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
    My screwdriver does not want to unscrew those. They won’t turn at all.
    Rei - Antwoord
    Got the same, used PH #0 and grabbed wireless card casing with fingers from the top to release pressure on screen and avoid (possibly) breaking it.
    Yuriy Zhyromskiy - Antwoord
    Some PS vita models seem to use a T2 screw instead of a PH#00. I’ve encountered this twice now.
    kaosjr kaosjr - Antwoord
    I replaced de wifi card but is still difficult to connect to wifi. Could it be the wifi antenna? which cable model is it?
    Fernando Diaz - Antwoord
    3G Vita 1000.
    I found that the PH00 head wouldn't actually fit in to the screw correctly. A PH000 fit but was still requiring a bit more force than seemed necessary. Also the card did not pop up when the screws were released and that's because Sony used a tacky pad under the card so needed a bit of prying up to get the angle.
    Paul Pimm - Antwoord
  12. PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: stap 12, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: stap 12, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: stap 12, afbeelding 3 van 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
    Is this really necessary?
    fmind11 - Antwoord
  13. PlayStation Vita Start/Select Button Replacement: stap 13, afbeelding 1 van 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Start/Select Button Replacement: stap 14, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement: stap 14, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement: stap 14, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Start/Select Button Replacement: stap 15, afbeelding 1 van 2 PlayStation Vita Start/Select Button Replacement: stap 15, afbeelding 2 van 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Start/Select Button Replacement, Right Button Board: stap 16, afbeelding 1 van 2 PlayStation Vita Start/Select Button Replacement, Right Button Board: stap 16, afbeelding 2 van 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Start/Select Button Replacement: stap 17, afbeelding 1 van 2 PlayStation Vita Start/Select Button Replacement: stap 17, afbeelding 2 van 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Start/Select Button Replacement: stap 18, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement: stap 18, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement: stap 18, afbeelding 3 van 3
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Start/Select Button Replacement: stap 19, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement: stap 19, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement: stap 19, afbeelding 3 van 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Start/Select Button Replacement: stap 20, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement: stap 20, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement: stap 20, afbeelding 3 van 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Start/Select Button Replacement, Start/Select Button: stap 21, afbeelding 1 van 3 PlayStation Vita Start/Select Button Replacement, Start/Select Button: stap 21, afbeelding 2 van 3 PlayStation Vita Start/Select Button Replacement, Start/Select Button: stap 21, afbeelding 3 van 3
    • Using tweezers, peel the start/select button off the back case.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.868 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.648 handleidingen geschreven
1Gids Commentaar
So I hit a roadblock at step 11, it seems some of these devices have security screws with no specific bit (or at least not one I could find) on the network card, so if you plan on attempting this repair please check your network card before doing so as you may need to perform some extra steps (such as cutting at the thing with a dremel if you're comfortable with that...) before moving forward. Here's what I'm referring to
Celestial Nomad - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 68
Altijd: 7,988
