Ga door naar hoofdinhoud
PlayStation 4 Pro Power Supply Unit Replacement
Wat je nodig hebt
  1. PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 3 van 3
    • Begin by flipping the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
    Vraag FixBot
    Voeg opmerking toe
  2. PlayStation 4 Pro Power Supply Unit Replacement: stap 2, afbeelding 1 van 2 PlayStation 4 Pro Power Supply Unit Replacement: stap 2, afbeelding 2 van 2
    • Use a screwdriver to remove the single Phillips #0 screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
    Vraag FixBot
    Voeg opmerking toe
  3. PlayStation 4 Pro Power Supply Unit Replacement: stap 3, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 3, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 3, afbeelding 3 van 3
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
    Vraag FixBot
    Voeg opmerking toe
  4. PlayStation 4 Pro Power Supply Unit Replacement: stap 4, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 4, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 4, afbeelding 3 van 3
    • Use a T8 Torx Security screwdriver to remove the five screws.
    • Two 31mm screws.
    • Three 10mm screws.
    • Remove the metal plate.
    Vraag FixBot
    Voeg opmerking toe
  5. PlayStation 4 Pro Power Supply Unit Replacement: stap 5, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 5, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 5, afbeelding 3 van 3
    • Flip the console to its back once again.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
    • Remove the bottom cover in the same way as the top cover. Grip on both sides, pull up until a click is heard and slide off.
    Vraag FixBot
    Voeg opmerking toe
  6. PlayStation 4 Pro Power Supply Unit Replacement: stap 6, afbeelding 1 van 2 PlayStation 4 Pro Power Supply Unit Replacement: stap 6, afbeelding 2 van 2
    • Use a T8 Torx security screwdriver to remove the two 10mm silver screws from the metal plate.
    Vraag FixBot
    Voeg opmerking toe
  7. PlayStation 4 Pro Power Supply Unit Replacement: stap 7, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 7, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 7, afbeelding 3 van 3
    • Flip the console over to continue working on the top side.
    • Place fingers underneath edge of power supply unit on both sides and pull straight up.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
46 andere personen hebben deze handleiding voltooid.
Ashlyn Chow
4.051 Reputatie
1 Handleiding geschreven
Cal Poly, Team S21-G5, Livingston Spring 2017 Lid van Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 Leden
49 handleidingen geschreven
10Gids Commentaar
Thank you soooo much for helping me save my ps4 pro guys! At the moment I love you like no one before! ;D
Fayce D D - Antwoord Deel
Can you go further in your tear-down and show us how to open up the power supply without breaking the PSU plastic case? Thanks. ^_^
Matt - Antwoord Deel
I bought a PS4 power supply CR 300 and my PS4 has an FR 300 power supply will they interchange
joseph fish - Antwoord Deel
My PlayStation Pro has a power supply FR 300 and the power supply I bought was a CR 300 power supply will they interchange
Hola como saber que tipo de fuente vida mi ps4 pro modelo 7215b
Tomás Javier - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 29
Afgelopen 7 dagen: 193
Afgelopen 30 dagen: 750
Altijd: 111,943
