Ga door naar hoofdinhoud
PlayStation 3 Blu-ray Disc Drive Replacement
Wat je nodig hebt
  1. PlayStation 3 Blu-ray Disc Drive Replacement, Smart Plate: stap 1, afbeelding 1 van 2 PlayStation 3 Blu-ray Disc Drive Replacement, Smart Plate: stap 1, afbeelding 2 van 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    Vraag FixBot
    Voeg opmerking toe
  2. PlayStation 3 Blu-ray Disc Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    Vraag FixBot
    Voeg opmerking toe
  3. PlayStation 3 Blu-ray Disc Drive Replacement: stap 3, afbeelding 1 van 3 PlayStation 3 Blu-ray Disc Drive Replacement: stap 3, afbeelding 2 van 3 PlayStation 3 Blu-ray Disc Drive Replacement: stap 3, afbeelding 3 van 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    Vraag FixBot
    Voeg opmerking toe
  4. PlayStation 3 Blu-ray Disc Drive Replacement: stap 4, afbeelding 1 van 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    Vraag FixBot
    Voeg opmerking toe
  5. PlayStation 3 Blu-ray Disc Drive Replacement, Top Cover: stap 5, afbeelding 1 van 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
    Vraag FixBot
    Voeg opmerking toe
  6. PlayStation 3 Blu-ray Disc Drive Replacement: stap 6, afbeelding 1 van 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
    Vraag FixBot
    Voeg opmerking toe
  7. PlayStation 3 Blu-ray Disc Drive Replacement, Blu-ray Disc Drive: stap 7, afbeelding 1 van 1
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  8. PlayStation 3 Blu-ray Disc Drive Replacement: stap 8, afbeelding 1 van 1
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  9. PlayStation 3 Blu-ray Disc Drive Replacement: stap 9, afbeelding 1 van 3 PlayStation 3 Blu-ray Disc Drive Replacement: stap 9, afbeelding 2 van 3 PlayStation 3 Blu-ray Disc Drive Replacement: stap 9, afbeelding 3 van 3
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
159 andere personen hebben deze handleiding voltooid.
16Gids Commentaar
Most helpful. Thx need to buy parts.and tools needed to fix game game. Were to buy ?
The Unknown Soldier - Antwoord Deel
Not sure myself, need one too. Look under comments section under ps3 laser replacement for more info. They are supposed to sell them on this website but I think they are still out.
Brian Parks - Antwoord Deel
Can I use any fat PS3 blu-ray drive in a fat PS3 or do I need a certain on????? I have a 80gb fat PS3
tonyhb - Antwoord Deel
No, you need a certain one + you have to take off the daughter board from your old drive and put it on the new one.
aangelcg - Antwoord Deel
Very helpful
Machaulay pastorini - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 31
Afgelopen 7 dagen: 212
Afgelopen 30 dagen: 1,057
Altijd: 421,431
