Ga door naar hoofdinhoud
Plantronics Voyager Legend Earpiece Replacement
Wat je nodig hebt
  1. Plantronics Voyager Legend Earpiece Replacement, Earpiece: stap 1, afbeelding 1 van 3 Plantronics Voyager Legend Earpiece Replacement, Earpiece: stap 1, afbeelding 2 van 3 Plantronics Voyager Legend Earpiece Replacement, Earpiece: stap 1, afbeelding 3 van 3
    • Remove the soft, plastic earpiece.
    • Depress the soft, plastic earpiece. While depressed, rotate the earpiece counterclockwise ninety degrees.
    • List the soft, plastic earpiece out of its position.
  2. Plantronics Voyager Legend Earpiece Replacement: stap 2, afbeelding 1 van 1
    • Heat the earpiece assembly with a heat gun (a hair dryer will work if a heat gun is not available).
    • The heating softens the adhesive that holds the assembly together, and the assembly may need to be reheated to complete the dis-assembly process.
  3. Plantronics Voyager Legend Earpiece Replacement: stap 3, afbeelding 1 van 2 Plantronics Voyager Legend Earpiece Replacement: stap 3, afbeelding 2 van 2
    • The two snaps that combine with the adhesive to hold the assembly together are located in the neck of the earpiece unit.
  4. Plantronics Voyager Legend Earpiece Replacement: stap 4, afbeelding 1 van 2 Plantronics Voyager Legend Earpiece Replacement: stap 4, afbeelding 2 van 2
    • Remove the top half of the earpiece assembly.
    • Use the pointed end of a small, metal Spudger to loosen the two tabs that hold the earpiece assembly together.
    • While glue is soft and snaps are loosened, remove the entire top half of the earpiece housing.
  5. Plantronics Voyager Legend Earpiece Replacement: stap 5, afbeelding 1 van 3 Plantronics Voyager Legend Earpiece Replacement: stap 5, afbeelding 2 van 3 Plantronics Voyager Legend Earpiece Replacement: stap 5, afbeelding 3 van 3
    • Remove the speaker housing.
    • With the copper backing plate displayed, use the pointed end of a small, metal Spudger to disassemble the speaker housing.
    • Using the pointed end of the small, metal Spudger, lift the copper, backing plate away from the speaker unit.
  6. Plantronics Voyager Legend Earpiece Replacement: stap 6, afbeelding 1 van 2 Plantronics Voyager Legend Earpiece Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use Precision Tweezers to remove the protective screen from the front of the speaker unit.
  7. Plantronics Voyager Legend Earpiece Replacement: stap 7, afbeelding 1 van 3 Plantronics Voyager Legend Earpiece Replacement: stap 7, afbeelding 2 van 3 Plantronics Voyager Legend Earpiece Replacement: stap 7, afbeelding 3 van 3
    • Remove the speaker unit and solder a new unit in place.
    • When disconnecting leads, always disconnect as near as possible to the component being replaced, to allow room for reattachment.
    • Locate the leads that connect to the back of the speaker unit.
    • Disconnect the leads from the back of the speaker unit.
    • Remove the speaker unit, and replace by soldering the leads back into their correct locations.
    • Refer to the iFixit soldering guide for assistance with soldering.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Lewis Certain
2.287 Reputatie
3 handleidingen geschreven
Één opmerking
Thank you for the Guide.
One further Question is open for me: How do you replace the broken rubber near the earpiece?
albert einstein - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 82
Altijd: 16,127
