Ga door naar hoofdinhoud
Planet Eclipse Etha Eyes Replacement
Wat je nodig hebt
    1. Planet Eclipse Etha Eyes Replacement, Regulator: stap 1, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement, Regulator: stap 1, afbeelding 2 van 2
      • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
      • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
      • The macroline is the black hose connecting the regulator to the tank connection.
      Vraag FixBot
      Voeg opmerking toe
    2. Planet Eclipse Etha Eyes Replacement: stap 2, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement: stap 2, afbeelding 2 van 2
      • Remove the regulator by unscrewing it in a clockwise direction.
      Vraag FixBot
      Voeg opmerking toe
    1. Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: stap 3, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: stap 3, afbeelding 2 van 2
      • Use the 5/64" hex key to remove the screw shown.
      • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
      • If you are only replacing the battery, skip the next step.
      • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
      Vraag FixBot
      Voeg opmerking toe
    2. Planet Eclipse Etha Eyes Replacement: stap 4, afbeelding 1 van 1
      • Flip the marker over and use the 5/64" hex key to remove the screw shown.
      Vraag FixBot
      Voeg opmerking toe
    3. Planet Eclipse Etha Eyes Replacement: stap 5, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement: stap 5, afbeelding 2 van 2
      • Carefully remove the 9V battery and connector.
      • Remove the 9V battery from the connector.
      Vraag FixBot
      Voeg opmerking toe
    1. Planet Eclipse Etha Eyes Replacement, Frame: stap 6, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement, Frame: stap 6, afbeelding 2 van 2
      • Carefully disconnect the three connectors from the circuit board.
      • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
      Vraag FixBot
      Voeg opmerking toe
    2. Planet Eclipse Etha Eyes Replacement: stap 7, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement: stap 7, afbeelding 2 van 2
      • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
      Vraag FixBot
      Voeg opmerking toe
    3. Planet Eclipse Etha Eyes Replacement: stap 8, afbeelding 1 van 1
      • Be very careful during the step to avoid damage to the solenoid or wiring.
      • Gently separate the top and bottom of the marker.
      Vraag FixBot
      Voeg opmerking toe
    1. Planet Eclipse Etha Eyes Replacement, Eyes: stap 9, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement, Eyes: stap 9, afbeelding 2 van 2
      • Use the 5/64" hex key to turn the screw counterclockwise.
      • Carefully remove the screw and place it off to the side.
      • Remove the panel and place it off to the side.
      Vraag FixBot
      Voeg opmerking toe
    2. Planet Eclipse Etha Eyes Replacement: stap 10, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement: stap 10, afbeelding 2 van 2
      • Carefully flip the marker over.
      • Remove the screw and place it off to the side.
      • Carefully remove the panel and place it off to the side.
      Vraag FixBot
      Voeg opmerking toe
    3. Planet Eclipse Etha Eyes Replacement: stap 11, afbeelding 1 van 2 Planet Eclipse Etha Eyes Replacement: stap 11, afbeelding 2 van 2
      • Grip the marker with one hand and gently pull the eyes out with your other hand.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hannah Lancaster
132 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-42, Amido Fall 2014 Lid van Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Leden
63 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 1,576
