Ga door naar hoofdinhoud
Pipo Smart S1 Speaker Replacement
Wat je nodig hebt
  1. Pipo Smart S1 Speaker Replacement, Battery: stap 1, afbeelding 1 van 3 Pipo Smart S1 Speaker Replacement, Battery: stap 1, afbeelding 2 van 3 Pipo Smart S1 Speaker Replacement, Battery: stap 1, afbeelding 3 van 3
    • Insert an iFixit opening tool between the body and display of the tablet at the bottom of the device where the charging port is.
    • Slide the tool along the gap you are creating, moving to the right direction against the mini USB port.
  2. Pipo Smart S1 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Gently pry the body of the tablet and pop the back cover open.
    • Lift the back cover of the device and place it on the side.
  3. Pipo Smart S1 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Lift the edge of the white tape with the iFixit opening tool.
  4. Pipo Smart S1 Speaker Replacement: stap 4, afbeelding 1 van 2 Pipo Smart S1 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Lift the white tape with your fingers, then lift the yellow tape that holds the battery extension.
  5. Pipo Smart S1 Speaker Replacement: stap 5, afbeelding 1 van 1
    • On the bottom of your tablet, use the Phillips #0 screwdriver to take the two 3mm screws out.
  6. Pipo Smart S1 Speaker Replacement: stap 6, afbeelding 1 van 2 Pipo Smart S1 Speaker Replacement: stap 6, afbeelding 2 van 2
    • Lift the headphone jack and move it to the other side, placing it on the surface you are working on.
  7. Pipo Smart S1 Speaker Replacement: stap 7, afbeelding 1 van 2 Pipo Smart S1 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to pry the battery and detach it from the glue underneath it.
    • Be careful not to pinch the battery—lithium batteries are hazardous and prone to short circuiting, and thus burning and/or exploding.
  8. Pipo Smart S1 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Lift the battery and place it a little further away from the positive and negative battery wires.
  9. Pipo Smart S1 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Using your soldering iron, melt the two lead spots to detach the wires.
    • The soldering iron is extremely hot, so handle with caution. Always keep the soldering iron holder next to you when using it so you can return it easily.
    • When reassembling, make sure you solder the right pole to the right spot on the circuit board, as swapping them can burn the motherboard.
  10. Pipo Smart S1 Speaker Replacement: stap 10, afbeelding 1 van 2 Pipo Smart S1 Speaker Replacement: stap 10, afbeelding 2 van 2
    • Remove the two wires. Then remove the battery completely from the device.
    • Make sure you tape the negative and positive battery wires to keep them from short-circuiting.
  11. Pipo Smart S1 Speaker Replacement, Speaker: stap 11, afbeelding 1 van 1
    • Find the charging port at the bottom of your device.
    • Insert the spudger into the seam between the front and back panels of the device.
  12. Pipo Smart S1 Speaker Replacement: stap 12, afbeelding 1 van 2 Pipo Smart S1 Speaker Replacement: stap 12, afbeelding 2 van 2
    • Slide the spudger away from the charging port.
    • Continue doing this around the entire device to separate the front and back cover.
  13. Pipo Smart S1 Speaker Replacement: stap 13, afbeelding 1 van 1
    • Using your fingers, pry off the back cover of the device once you have created a gap between the covers.
  14. Pipo Smart S1 Speaker Replacement: stap 14, afbeelding 1 van 1
    • Find the speaker at the bottom of the tablet.
    • The speaker looks like a black oval with a red and black wire connected to it.
  15. Pipo Smart S1 Speaker Replacement: stap 15, afbeelding 1 van 2 Pipo Smart S1 Speaker Replacement: stap 15, afbeelding 2 van 2
    • Pry out the speaker using the spudger.
    • Alternate sides to help avoid damage to the speaker's molding.
  16. Pipo Smart S1 Speaker Replacement: stap 16, afbeelding 1 van 2 Pipo Smart S1 Speaker Replacement: stap 16, afbeelding 2 van 2
    • Use your fingers to pull the speaker out of the device.
  17. Pipo Smart S1 Speaker Replacement: stap 17, afbeelding 1 van 1
    • Place the defective speaker next to your device.
  18. Pipo Smart S1 Speaker Replacement: stap 18, afbeelding 1 van 1
    • Disconnect the speaker's wires from the motherboard using the soldering iron.
    • The soldering iron is extremely hot. Handle with caution. Keep the holder next to you and return the soldering iron to the holder when it is not in use.
  19. Pipo Smart S1 Speaker Replacement: stap 19, afbeelding 1 van 1
    • Reconnect the new speaker's wires to the motherboard using the soldering iron.
  20. Pipo Smart S1 Speaker Replacement: stap 20, afbeelding 1 van 3 Pipo Smart S1 Speaker Replacement: stap 20, afbeelding 2 van 3 Pipo Smart S1 Speaker Replacement: stap 20, afbeelding 3 van 3
    • Carefully place the new speaker into the speaker port.
    • Gently push down on the new speaker to properly connect it to the port.
Conclusie
Ali Alqallaf
340 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-6, Passmore Fall 2016 Lid van USF Tampa, Team 3-6, Passmore Fall 2016
USFT-PASSMORE-F16S3G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 191
