Ga door naar hoofdinhoud
Photive Hydra USB Connector Replacement
Wat je nodig hebt
  1. Photive Hydra USB Connector Replacement, Face Plate and Back Plate: stap 1, afbeelding 1 van 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra USB Connector Replacement: stap 2, afbeelding 1 van 2 Photive Hydra USB Connector Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra USB Connector Replacement: stap 3, afbeelding 1 van 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra USB Connector Replacement: stap 4, afbeelding 1 van 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra USB Connector Replacement: stap 5, afbeelding 1 van 2 Photive Hydra USB Connector Replacement: stap 5, afbeelding 2 van 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra USB Connector Replacement, Battery (Prerequisite): stap 6, afbeelding 1 van 2 Photive Hydra USB Connector Replacement, Battery (Prerequisite): stap 6, afbeelding 2 van 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra USB Connector Replacement: stap 7, afbeelding 1 van 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra USB Connector Replacement, USB Connector: stap 8, afbeelding 1 van 2 Photive Hydra USB Connector Replacement, USB Connector: stap 8, afbeelding 2 van 2
    • Identify the motherboard and three Phillips (Length-1/8", Head-1/8") screws and remove them using a #1 screwdriver.
  9. Photive Hydra USB Connector Replacement: stap 9, afbeelding 1 van 2 Photive Hydra USB Connector Replacement: stap 9, afbeelding 2 van 2
    • Pull the motherboard up and out to remove.
  10. Photive Hydra USB Connector Replacement: stap 10, afbeelding 1 van 1
    • Identify the USB connector. Remove and replace the component with a functioning USB device. Refer to the link below for soldering techniques. Hoe moet je (de-)solderen?
Conclusie
Jose Muzaurieta
120 Reputatie
1 Handleiding geschreven
USF Tampa, Team 11-3, Cheng Spring 2016 Lid van USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Leden
6 handleidingen geschreven
3 opmerkingen
Any way to buy the entire motherboard? Any suggestion where can I buy it?
Abraham Hernandez - Antwoord
Where can I purchase the usb
Sonia Lance - Antwoord
Where can I purchase the usb. There are so meany I don't know how to tell the correct one. Thank
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 732
